Olive One Update: adesso si parla di Novembre per il delivery
Olive One Update: adesso si parla di Novembre per il delivery Empty Olive One Update: adesso si parla di Novembre per il delivery
Messaggio Da franz159 6th Ottobre 2013, 18:15
E così siamo ormai a 4 mesi di ritardo sulla data inizialmente pianificata per Luglio 2013.
Questo l'update ricevuto il 19/9 u.s.:
Dear Valued Backer,
Since our last update, we have made significant progress in Olive ONE's development. We want to share with you some key news and pictures of the first pre-production samples.
The Olive ONE has a single body die-casted aluminum enclosure, with a beautiful anodized finish and glossy glass touch-screen surface.
Olive ONE sports a user installable hard drive. Making the hard disk drive user installable involved solving a few design challenges.
The hard drive will now reside in a small compartment on the underside of the ONE.
As discussed in our last update email, we added premium-grade connectors directly to the Olive ONE, eliminating the need for the Olive PAC.
Notice something? We have added Gigabit Ethernet to the Olive ONE! Many of you requested Ethernet connectivity during the Indiegogo campaign, but we were unable to add it due to the limitations of the Marvel processor used in the original design.
ONE will now come with a brand new Freescale processor with significant performance benefits:
The new Freescale processor shows significant increases in navigation performance. Browsing through music libraries and transitions are now much more smooth and fluid. Additionally, video playback capability (e.g. for YouTube playback) improves considerably.
The change to a new processor is of course a major challenge, but the porting of our software has so far showed no major complications. Nevertheless, we want to communicate clearly that we still have not ported all of the software, and there might be unforeseen delays that can push the product delivery into November, which would be the worst case scenario.
At this point, we have used approximately 30% of the funds raised for tooling, PCB and enclosure prototyping and sourcing of key parts for the Bill of Material. Our accounting team is currently entering your contribution details and you will receive an official contribution confirmation from Olive soon, confirming your contribution amount, product model, shipping address and an estimated shipping date.
Thank you again for supporting this project and your amazing feedback over the last months. We understand that the delay in shipping is anything less than ideal, but we believe that implementing your feedback and key feature requests was worth the extra effort and cost. We hope you see it the same way.
E per chi fosse interessato anche qualche immagine:
  • Prototipo
  • Scomparto HDD
  • Uscite e connettori
Aggiungo che personalmente, nonostante il ritardo, sono contento delle modifiche apportate, in particolare Ethernet e l'uscita digitale coassiale!
franz159
Data d'iscrizione : 11.04.12
Numero di messaggi : 493
Provincia : New York
Impianto : Raspberry PiB+, IQ-Audio Pi Dac+ con Rune Audio
Geek Out 720 Usb Dac
Creek Evolution 50A
B&W CM5
MacBook Air con Audirvana+ 2.5.x
Raspberry Pi2, IQ-Audio Pi Dac con Kodi
Raspberry Pi3, Chord MoJo Dac su USB
Musical Paradise MP-301 MK3
Lepai LP7498E+
Elac UB5
Olive One Update: adesso si parla di Novembre per il delivery Empty Re: Olive One Update: adesso si parla di Novembre per il delivery
Messaggio Da jexoz 7th Ottobre 2013, 07:48
Comunque lo hanno modificato, è normale il ritardo.
La config finale è quellache i vari bakers a evano chiesto. Sono contento. Meglio aspettare qlc in più ma trovarsi un prodotto migliore. Oggi la fretta di mettere sul mercato è controproducente, la gente ha meno soldi e vuole spendere bene unasola volta. Aspetto novembre con i manchevoli ritardi delle poste.
jexoz
jexoz
Data d'iscrizione : 12.01.09
Numero di messaggi : 45
Impianto : PC DH101 con USB DAC Audio GD NFB3 oppure CD jvc con Lite DAC- Ampli: TA 10.1/ Virtue Two / Rotel 731 MKII / Sure 2024mod / Audiophonic T-Amp - Gainclone- Casse: Autocostruite 2 vie e mezzo in Appolito Visaton / Progetto TNT Lilliput da me Modificato - Cavi TNT Triple T ed Piano 6
Messaggio Da wincenzo 7th Ottobre 2013, 12:05
I ritardi sono figli delle modifiche in corso d'opera, tutte molto utili comunque.
Dopotutto hai comprato sulla carta e ci sta che ci siano un pò di ritardi, comunque niente di grave e l'attesa aumenta il piacere Very Happy
Il prodotto merita! bellissimo.
wincenzo
wincenzo
Data d'iscrizione : 10.07.08
Numero di messaggi : 2531
Messaggio Da franz159 7th Ottobre 2013, 23:16
wincenzo ha scritto:....I ritardi sono figli delle modifiche in corso d'opera, tutte molto utili comunque.....
  • Ethernet --> OK
  • Digital Out Coax --> OK
  • Analog Out Rca --> OK
  • Standard USB out --> OK
....tutto ok, sarò paziente....ancora un po'! Sad
franz159
Creek Evolution 50A
B&W CM5
Lepai LP7498E+
Elac UB5
Olive One Update: adesso si parla di Novembre per il delivery Empty domanda
Messaggio Da Teoz 18th Ottobre 2013, 15:12
Ciao sarei davvero interessato anche io a questo oggetto sarebbe perfetto per mè!!
Vorrei solo sapere se per acquistarlo ci sono altri canali, ed inoltre non ho ben capito
se l'unità base ha solo uscite audio, usb,coax e usb, mentre per il collegamento ai diffusori bisogna
acquistare a parte un altra unità?
A questo punto i primi esemplari dovremmo vederli quando?
ciao e grazie
Teoz
Teoz
Data d'iscrizione : 14.09.13
Numero di messaggi : 53
Impianto : Cyrus 8 dac+psx+castle Harlech+wdtvlive!
Messaggio Da franz159 19th Ottobre 2013, 19:05
Teoz ha scritto:...
se l'unità base ha solo uscite audio, usb,coax e usb, mentre per il collegamento ai diffusori bisogna acquistare a parte un altra unità?
Come puoi vedere nella foto del prototipo postata in
http://www.francescomoretta.com/foto/varie/oliveone/BACKSIDE.PNG
nell'unità base, cioè senza componenti aggiunti, ci sono uscite per (da sx a dx):
- una coppia di diffusori
- digitale coassiale
- analogica rca
- ethernet
- usb
Non ti so invece rispondere sui canali di vendita Olive in Italia, spero per Novembre mi arrivi come indicato nella loro ultima mail...
Franz
franz159
Creek Evolution 50A
B&W CM5
Lepai LP7498E+
Elac UB5
