Subwoofer attivo
+9
Josto
gasgas14
giammo
R!ck
elenesther
gianfry1973
13 partecipanti
Pagina 4 di 5 Precedente  1, 2, 3, 4, 5  Successivo
Subwoofer attivo - Pagina 4 Empty Re: Subwoofer attivo
Messaggio Da R!ck Gio 14 Lug 2011 - 18:33
Con 350 euro ti fai un sub da 20hz e 105 db di spl di picco...non male!
Dimenticavo un'altro ap interessante:
HI-VI SP 10 http://www.swanspeaker.com/products/products.aspx?cid=9&sid=60&pid=211.
Penso che questo componente vada messo in cassa chiusa...ma Paul Carmody ha usato un Reflex:
http://www.htguide.com/forum/showpost.php4?p=508562&postcount=54
http://techtalk.parts-express.com/showthread.php?t=211643
ma c'è anche questo:
http://diyaudioprojects.com/Speakers/HiVi-DIY-Subwoofer/
Se ti interessano un pò i subwoofer...ho trovato questa storia curiosa
In molti hanno notato similitudini tra questo ap e quello usato nei (vecchi) sunfire...ed il motivo esisterebbe:
Carver's wife is the queen of modern high excursion subwoofer drivers. Did you know that? Here's a little history that very few people are aware of: About the time the Bob Carver had arrived at his downtracking converter power supply he was going to build a subwoofer for himself. His wife informed him that she did not want any more large speakers in the room (even Bob has to deal with this sort of thing ). At this point he started to ponder the idea of what it would take to produce very deep and loud bass from a small package. He knew he could develop and amp that could drive it, but there were no woofers available that met his criteria....
So, Bob designed one. Most people don't know that he is the father of the modern long voice coil, large suspension, high excursion woofer, but he is. He came up with the idea of a woofer with a long coil, large spider, large surround, very large high BL motor, and heavy cone, and patented this type of driver. Nothing like it really existed before.
He then took his patent to a company named Ground Zero USA and they built the driver for him and this was the woofer in the original Sunfire True Subwoofer. Within a couple of years though, Ground Zero reorganized themselves as German company named Ground Zero GmbH, and a short time later began to produce their own drivers that were very similar to the ones being built for Carver. Bob believed this was patent infringement and the legal battles began.
During this time Carver met up with a German Engineer named Thilo Stompler and commissioned Thilo to build the Sunfire drivers at his new California company TC Sounds. The Sunfire Mk II, I believe contains this driver as well as some changes to the amplifier. Despite the patent and the legal battles, Ground Zero continued to produce these drivers, and still makes variants of it today which are sold primarily in Europe for car audio applications.
After a while the cost of TC Sounds drivers began to rise quickly and Carver looked off-shore for an Asian OEM who could build drivers to his specifications at a much lower cost (don't all companies end up doing this eventually?). Hi-Vi got the nod, as they make drivers for many speaker companies around the world already. This is the woofer in the Sunfire Mk IV. The driver went through some modifications and after a certain number of years Hi-Vi was able to sell this original driver under their name and the SP-10 was introduced. I have personally measured the parameters of a Hi-Vi SP10 and the driver from a Sunfire Mk IV, and although neither actually measured exactly as the SP10 is advertised, they measured almost identical to each other. The only real difference I could see between the two drivers were the terminals used. Everything else, right down to the covers over the cone were exactly the same.
So there you have a little bit of the history. The large motor, long Xmax, large surround woofers that we see from many sources today all trace their lineage back to Bob Carver (and his wife's restrictions). Here's a quote from Vance Dickason on the subject - "There are many claims in Mr. Carver's patent(s) and perhaps this is an oversimplification, but it would seem that any further upward scaling of voice coil length, surround size and stiffness, and excursion in general are now the property of Mr. Carver."
In all fairness though, I should add that there were forerunners to the Carver design - companies like Jensen, Advent, and AR and others (JBL and EV on the pro side) progressively developed "long throw woofers". But the clearest forerunner was Cerwin-Vega. Gene Cerwinsky at CV made many small high excursion woofers for special pro applications in the 70's, including the driver for the old Infinity Servo-Statics, which were a true state of the art design at the time. The CV woofers had very long voice coils and larger surrounds, much like our modern woofers have. Later Cerwinsky hired Walter Hoffman, who help develop thicker surrounds that would not invert and high excursion passive radiators. The Hoffman name is important because he was Chief Engineer at Ground Zero when Carver first went to them.
Still, Bob patented many things in these designs, and most of our modern high excursion woofers are based on his patents, especially the high BL motors, which are a key to the performance of the driver.
Jeff B.
da qui http://techtalk.parts-express.com/showthread.php?t=219157
P.S. I sunfire sono in cassa chiusa se la storia è vera forse non ho tutti i torti a dire che questo componente vada usato in sp con un amplificatore robusto!
Ultima modifica di R!ck il Ven 15 Lug 2011 - 10:56 - modificato 1 volta.
R!ck
Data d'iscrizione : 03.09.09
Numero di messaggi : 4987
Provincia : ---
Impianto : -------------
Messaggio Da R!ck Gio 14 Lug 2011 - 22:58
Josto sto dando per scontato che l'uso che ne vuoi fare è anche filmico...altrimenti potresti usare un paio di subbetti da 8" sono più utili di quello singolo per gestire le risonanze della stanza...tipo il W8 750 in cassa chiusa c'è un bel 3d su CHF GIUGIU'.
Spesso ho letto in questo forum che il sub non serve nei film...ma quali commedie e film d'autore?
Subwoofer attivo - Pagina 4 Alberop
Sono le frequenze usate nella traccia in una famosa scena di avatar quella dell'albero...con un 2 canali che arriva a 50hz...come si fa a riprodurlo?
http://www.avmagazine.it/forum/showthread.php?t=195831&highlight=misurazioni+lfe+avatar
R!ck
Provincia : ---
Messaggio Da Josto Gio 14 Lug 2011 - 23:29
Mi ha fatto piacere leggere il fatto su Bob Carver, a me i suoi prodotti sono sempre piaciuti, un tempo stavo per prendere un CM 1090....ma non avevo idea che fosse dietro a Sunfire (se non ho capito male).
Ho simulato l'Hivi, in un box da 50 litri in reflex con il plate amp che ho preso dovrebbe fare tranquillamente 103.9 db@20 Hz...inoltre costa 160 euro Dribbling
Andrebbe ad essere il sub di un sistema 2.1 collegato (dei sat ho già il mdf tagliato a misura, un progetto per recuperare degli AP che ho sparsi per casa) ad un Media Center, quindi gli sarebbe richiesto un funzionamento in tutte le situazioni anche se in un condominio e quindi eccetto rare occasioni a volumi civili.
Avevo letto dei giù giù...che erano realizzati con dei TangBand se non mi ricordo male...però c'era qualcosa che non mi aveva convinto del tutto, anche se la SP mi aveva fatto seguire il thread. Very Happy
Altro fattore da non trascurare è che un box da 50 lt penso di riescire - ed è paradossale - a mimetizzarlo meglio nell'ambiente ed infine ho la convinzione che due 8" non abbiano la possibilità di darmi l'impatto che se dovessi spostarli di location (ho una casa in campagna) desidererei (ecco anche il perchè della ricerca di un 12").
Josto
Josto
Data d'iscrizione : 24.09.10
Numero di messaggi : 661
Provincia : Volubile
Messaggio Da R!ck Ven 15 Lug 2011 - 9:55
Sunfire l'ha fondata lui ma avevo letto che l'ha venduta tempo fa.
L'hivi lo prenderei proprio per costruire qualcosa di compatto...altrimenti costa troppo! I 250 watt vanno bene in reflex altrimenti sono pochini
Non ho capito se Carmody ha verificato le misure del SP10...alcune persone tra cui quel Jeff B. (...ma so anche Matarrazzo) hanno rilevato parametri molto lontani da quelli dichiarati. Bisognerebbe chiedere a quel Jeff. B. ma non riesco ad iscrivermi al forum di part express
Dove lo hai trovato? E' un pò che non lo vedo in giro!
R!ck
Provincia : ---
Messaggio Da Josto Ven 15 Lug 2011 - 17:03
Audiophonics
Per dei sub in sospensione pneumatica per guadagnare db ci vogliono fantastilioni di watt o, nel caso del giugiù, almeno 4 scatolotti....
L'Hivi si comporta bene in entrambi i casi, ma ormai il plate lo ho comprato e ho il limite dettato dalla potenza di quest'ultimo, lo spazio come già detto in qualche modo non è un problema (ho la seduta del divano pronta ad ospitarlo, oppure ci farei una sorta di puff)...avrei potuto prendere un amp PA in classe D + un xover elettronico + eventuale equalizzatore, ma i costi sarebbero lievitati eccessivamente, anche se sicuramente la soluzione qualittivamente migliore.
Dovrei contattare Axiomedia per sapere il prezzo del TB WQ-1858 che è un componente interessante, anche se non ho fatto alcuna simulazione Hehe
Jeff B.=Jeff Bagby
Josto
Josto
Messaggio Da gianfry1973 Sab 16 Lug 2011 - 19:41
Il venditore inglese ha di nuovo disponibili gli eminence, oltre agli xxls12 per cassa chiusa e gli xls 10'
http://shop.ebay.co.uk/colosussxb/m.html?_nkw=&_armrs=1&_from=&_ipg=25
Con il nostro plate la SP è da evitare, poca ciccia..
l'xls10 da allineare in reflex è ancora piu "ostico" dell'xls12..ma c'è chi, sfruttando il bass boost lo fa andare lo stesso (ma a me non piace particolarmente come soluzione):
http://www.subwoofer-builder.com/driver-P-830452.htm
Se uno non si fa condizionare dal foam l'eminence rimane un'ottima occasione.
Continuo a pensare che il CSS SDX10 sia un'ottimo componente..qui il datasheet http://www.creativesound.ca/pdf/CSS-SDX10-data-140408.pdf
dove ci sono anche i consigli del produttore per il mobile
lo trovi a 160€ da Rumoh http://www.rumoh.nl/en/creative-sound-solutions/802-css-sdx10.html
Ecco uno dei tanti progetti realizzati che puoi trovare in rete, l'amplificatore utilizzato è di potenza simile al nostro.
http://www.hometheatershack.com/forums/creative-sound-solutions/16450-css-sdx10-ported-build-thread.html
gianfry1973
Data d'iscrizione : 05.04.11
Numero di messaggi : 46
Impianto : Sintoampli Yamaha Rx-V667
Messaggio Da R!ck Sab 16 Lug 2011 - 19:55
Il progetto più "famoso" su questo ap è questo:
http://www.vikash.info/audio/xls10/
Grande estensione...ma ahimè sempre col passivo Smile
Gianfry il CSS IMHO è pò costoso.
Per me a quel punto meglio un 12" o se si vuole stare sul 10" il seas l26Roy a 145 euro
Fio adesso il Lab12 rimane quello con q/p più favorevole...per un reflex
R!ck
Provincia : ---
Messaggio Da Fabio Sab 16 Lug 2011 - 23:51
gianfry1973 ha scritto:Il venditore inglese ha di nuovo disponibili gli eminence, oltre agli xxls12 per cassa chiusa e gli xls 10'
Se vi serve una testimonianza, per quel che possa valere, il venditore è affidabile.
Il mio BK l'ho acquistato da lui qualche anno fa, ho pagato relativamente molto poco di spedizione, considerati i prezzi correnti dall'inghilterra, e mi è arrivato in meno di una settimana.
Lo avevo consigliato anche a Gianluca, che invece ha preferito ordinare il suo eminence altrove, pagandolo di piu'.
A dire il vero è stato un ripiego casuale all'autocostruzione, anche allora aveva in vendita i peerless, ma invece degli Emminence aveva degli Audio Drive "AD-vattelappesca312vattelappesca" da 12 pollici.
Se non ricordo male, cosa che non è esclusa, quelli si avevano parametri molto interessanti anche per la cassa chiusa, in 40 litri scendevano a circa 40-45 hertz di F3 e all'epoca venivano usati anche in casa BK per modelli maggiori al mio XLS200.
Purtroppo non ne ho trovato più traccia in tutto il web e credo non vengano più prodotti.
Fabio
Fabio
Data d'iscrizione : 02.11.08
Numero di messaggi : 2518
Provincia : pessimo
Messaggio Da Josto Dom 17 Lug 2011 - 18:21
Grazie della segnalazione.
L'Eminence per ora è il candidato più serio, uno di questi giorni chiedo i disegni del 3Pi
Josto
Josto
Messaggio Da Josto Dom 17 Lug 2011 - 18:22
Indicativamente quanti euro ti è costata la spedizione dal UK? Very Happy
Josto
Josto
Messaggio Da Fabio Lun 18 Lug 2011 - 11:22
Josto ha scritto:Indicativamente quanti euro ti è costata la spedizione dal UK? Very Happy
E passato del tempo e potrei dire una cazzata ma mi sembra di ricordare sui 25-30 euro, che per il peso e il paese di provenienza è veramente poco.
Ho visto sparare cifre superiori ai 100 euro per oggetti del genere.
Fabio
Fabio
Provincia : pessimo
Messaggio Da gianfry1973 Lun 18 Lug 2011 - 12:47
Riguardo la spedizione posso dire che l'ebayer inglese la fa pagare circa 30€ (gliel'ho chiesto).
Una domanda a chi ne sa qualcosa: giocando con winisd ho provato a mettere una resistenza in serie di 3 ohm. Risultato:
Subwoofer attivo - Pagina 4 Scherm10
La risposta si è molto linearizzata (grafico rosso), perdendo efficienza sopra gli 70hz, cosa ininfluente visto l'uso che ne andrò a fare.
Se a questo applico un boost di 5db a 21,5hz (ho fatto una media, nel mio plate è possibile impostare un boost che agisce nelle frequenze comprese tra 20 e 23hz sostituendo 2 resistenze con altrettante dell'adeguato valore) ottengo questo:
Subwoofer attivo - Pagina 4 Scherm11
Non ho esperienze su resistenze in serie su un sub, che voi sappiate ci sono controindicazioni?
gianfry1973
Messaggio Da Fabio Lun 18 Lug 2011 - 13:01
Fossi in te lascierei perdere resitenze in serie di valore paragonabile all'impedenza del sub, non hai a che fare con un tweeter.
Fabio
Fabio
Provincia : pessimo
Messaggio Da gianfry1973 Lun 18 Lug 2011 - 15:02
Infatti l'ho detto, non ho alcuna esperienza a riguardo, ma immaginavo potesse essere un'idea malsana..l'idea è nata semplicemente leggendo questo:
http://www.lautsprechershop.de/hifi/b_sph450_en.htm
Giusto per capire, che problemi ci sarebbero?
gianfry1973
Messaggio Da sonic63 Lun 18 Lug 2011 - 15:09
gianfry1973 ha scritto:Infatti l'ho detto, non ho alcuna esperienza a riguardo, ma immaginavo potesse essere un'idea malsana..l'idea è nata semplicemente leggendo questo:
Secondo me dopo che hai spento l'impianto vai ancora in giro per la stanza a raccogliere i bassi. Laughing
Data d'iscrizione : 21.12.09
Messaggio Da gasgas14 Lun 18 Lug 2011 - 15:20
Mah, io credo che Fabio stesse parlando d'altro, qualcosa di più "serio" credo.
Fabio, illuminaci.
gasgas14
gasgas14
Data d'iscrizione : 11.04.11
Numero di messaggi : 143
Occupazione/Hobby : Studente
Messaggio Da sonic63 Lun 18 Lug 2011 - 15:22
Very Happy
Fabio, illuminaci.
Perchè pensi che io sto scherzando?
Very Happy
Messaggio Da gasgas14 Lun 18 Lug 2011 - 15:44
Very Happy
Ma no, speravo infatti non fraintendessi, ma effettivamente poteva essere frainteso quanto ho detto.
Intendevo che da quanto ho capito tu parli di un eccesso di basse frequenze utilizzando un po' di bass boost, mentre Fabio credo intendesse altro, forse proprio parlando di accoppiamenti elettrici.. ma come dico aspetto che spieghi meglio, perché non ne so molto in tal caso..
gasgas14
gasgas14
Messaggio Da sonic63 Lun 18 Lug 2011 - 16:13
Very Happy
Beh, forse è colpa mia, l'ho messa come fosse una battuta, ma secondo me, tra bass reflex, + 5 db a 21Hz e resistenze in serie al woofer non mi aspetto un basso molto smorzato, veloce e intellegibile.
Però questa è la mia opinione che di diffusori ne capisco poco e di programmi di simulazione ancora meno.
Per questo sto seguendo con interesse questo 3d, sono molto curioso.
P.S. tu dici : << utilizzando un po' di bass boost >>, +5 db a 21Hz significa che l'ampli a quella frequenza deve erogare quasi 4 volte la potenza che sta erogando sul resto delle frequenze, dove credi che prenderà la corrente?
Non dimenticare che quella è una simulazione. Very Happy
Messaggio Da gianfry1973 Lun 18 Lug 2011 - 18:49
Ho trovato un po di spiegazioni sul discorso resistenze in serie. Non è tanto chiaro ma da quello che posso capire mi trovo nelle condizioni giuste (basso qts) per usare delle resistenze in serie..
http://www.lautsprechershop.de/hifi/aka_tief_it.htm
(niente, sto link non va..andate su Teorie: ToniBassi)
Una cosa non mi è chiara: se, ad esempio, mettessi una resistenza da 3 ohm 20W non la friggo in pochi minuti? O si dovrebbe usare varie resistenze in parallelo per raggiungere il wattaggio adatto e poi in serie a gruppi per ottenere la resistenza voluta? Mmm
gianfry1973
Messaggio Da Josto Lun 18 Lug 2011 - 19:04
Lo fa anche Giussani per modificare i parametri di un Beyma (mi pare) che nella sezione bassi di un diffusore per autocostruttori (o di cui comunque ha diffuso gli schemi).
Mi pare di ricordare che però la resistenza sia di valore minore, in sintesi a quanto ho capito modifica i parametri TS del altoparlante.
Se usi Bass30 quando inserisci i parametri del driver puoi vedere come si modificano i parametri sia per una massa aggiunta che per un R in serie. Hehe
Josto
Josto
Messaggio Da Josto Lun 18 Lug 2011 - 19:11
Very Happy
Anche i db di boost del plate amp non hanno una corrispondenza esatta, ecco cosa dice nella pagine del manuale:
Subwoofer attivo - Pagina 4 Catturatu.th
Josto
Josto
Messaggio Da gasgas14 Lun 18 Lug 2011 - 19:22
Orpo! Beh in effetti mi sembrano un po' troppi +5dB... io direi al massimo +3dB...
gasgas14
gasgas14
Messaggio Da sonic63 Lun 18 Lug 2011 - 19:26
Josto ha scritto:
Very Happy
va bene 4,65db invece di 5db.
Nell'esempio il boost è a 30Hz e a 20 hz le due configurazioni producono la stessa pressione. Almeno questo è quello che io ho tradotto dall'inglese e ho capito dal grafico( che non mi sembra una simulazione ma una misura)
Secondo te, guardando le due curve: quella con la gobba e quella con la pendenza meno ripida lato basse, quale suonerà meglio?
Messaggio Da sonic63 Lun 18 Lug 2011 - 19:30
A me anche 3 db sembrano troppi (perchè ci vuole un ampli che abbia la dinamica per farlo ...a 21 Hz poi....non è mica uno scherzo), comunque i 5 db non li abbiamo scelti nè io nè te, ne prendiamo solo atto e vediamo come va a finire Very Happy
