Genius33D: dalla cina con (nuovo) furore !
Genius33D: dalla cina con (nuovo) furore ! Empty Genius33D: dalla cina con (nuovo) furore !
Messaggio Da Marco Ravich Mar 23 Ago 2011 - 17:07
DSP+TAS5630+SMPS 2.1 OR THREE WAY HI-FI AMP WITH ANALOG/SPDIF/USB SOURCE SELECTOR
DSP processor inside:
We use advanced series dsp chip for our dsp amp,it is a complete single-chip audio system with a 28-/56-bit audio DSP, ADCs, DACs, and microcontroller-like control interfaces. Signal processing includes equalization, cross-over, bass enhancement, multiband dynamics processing, delay compensation, speaker compensation, and stereo image widening. This processing can be used to compensate for real-world limitations of speakers, amplifiers, and listening environments, providing dramatic improvements in perceived audio quality.
Its signal processing is comparable to that found in high end studio equipment. Most processing is done in full 56-bit, double precision mode, resulting in very good low level signal perfor-mance. It is a fully programmable DSP. The easy to use SigmaStudio™ software allows the user to graphically configure a custom signal processing flow using blocks such as biquad filters, dynamics processors, level controls, and GPIO interface controls.
High sample rate digital source support
High fidelity digital source support due to adanced asynchronous same rate processor and high speed audio dsp inside,it can support digital rate like fs=8kHz/11kHz/16Khz/22kHz/32kHz/44.1KHz/48Khz/96kHz/192kHz
Genius33D: dalla cina con (nuovo) furore ! DSP-TAS5630-SMPS-2-1-OR-THREE-WAY-HI-FI-AMP-WITH-ANALOG-SPDIF-USB-SOURCEGenius33D: dalla cina con (nuovo) furore ! 394630888_036Genius33D: dalla cina con (nuovo) furore ! 394394098_903
Uhm... tutto integrato: DAC, SMPS ed ampli.
Voi che ne dite ?
Data d'iscrizione : 20.04.09
Numero di messaggi : 6070
Provincia : MC
https://www.forart.it/
Genius33D: dalla cina con (nuovo) furore ! Empty Re: Genius33D: dalla cina con (nuovo) furore !
Messaggio Da flovato Mar 23 Ago 2011 - 17:15
Marco Ravich ha scritto:
Voi che ne dite ?
Dico che sono stufo di fare da cavia... Hehe Hehe Hehe
Qualcuno lo compri e ci dica come suona, potrebbe essere una valida alternativa al Muse DT50.
Per quanto riguarda i DAC interni mai trovato uno che suonasse decentemente, in ogni caso ci si può sempre accontentare. Oki
UTENTE BANNATO
Data d'iscrizione : 23.12.10
Numero di messaggi : 12509
Messaggio Da Marco Ravich Mer 24 Ago 2011 - 7:55
A me invece la cosa che non convince è che lo spacciano come un 3 vie, ma in realtà è al massimo un 2,5 vie (d'altro canto i chip di aplificazione 2 sono)...
...a quel prezzo preferisco il Dared DV-6C (anche se non ha il DAC).
Provincia : MC
