Windows 7 RAMDisk
Windows 7 RAMDisk
Progetto molto interessante per chi possiede diversi giga di ram..
Windows caricato in una ramdisk ha prestazioni allucinanti...si pappa tranquillamente il mio ssd Crucial m4
Applies to the following versions of Windows out of the box:
Windows 7
Windows Server 2008 R2
Windows Embedded (7) (NT 6.x)
Summary of the method:
Install Windows to fixed-size VHD
Install FiraDisk driver
Load VHD into memory with Grub4Dos and boot it
Advantages of the method:
Ease of use and servicing of created infrastructure.
You can boot your VHD from HDD at any time if you need to make any changes to the image.
Windows's native VHD logic is used in that case.
If you need to boot it from RAM you do it with Grub4Dos.
All you have to do is select the corresponding menu entry at boot time.
This way it's really easy to move, copy or delete your images.
Qui trovate la guida...
http://tech.outcult.com/tutorials/winram/01/06.php
Videotutorial
https://www.youtube.com/watch?feature=player_embedded&v=mDW0pGmhU9Y
Consiglio windows 7 sp1 Embedded..che occupa meno e supporta nativamente l installazione su vhd
http://wunger.wordpress.com/2009/09/08/installing-windows-embedded-standard-windows-7-embedded-in-a-vhd-file/
Windows 7
Videotutorial
kurt10- Membro classe bronzo
Numero di messaggi : 1625
» pc windows
» Windows 8 RTM...
» Nuovo DAC Fiio E10
» Da windows a MAC: problemi
» MPD windows version
» Windows 8 RTM...
Ieri alle 15:41 Da ste-65
Ieri alle 13:08 Da mauretto
Ieri alle 12:47 Da jenw84
Ieri alle 8:54 Da RF14381
» Problema audio tv
» lenco l 75
» lenco l 75
» jbl Radiance 121 VX
» Nuovo Eversolo DMP A-10
» Switch - Preamp
