Miti audiofili da sfatare
Massimo
H. Finn
Qui una lista (in inglese) di alcuni miti che gli audiofili credono essere veri.
Ma che in realtà sono falsi.
Di alcuni se è già ampiamente parlato su questo forum ....
Fonte:
http://www.getbettersound.com/quarternotesv2i1.html
- Rooms with non-parallel walls sound better.
- The “rule of thirds” is a great set-up guide.
- Cathedral ceilings provide great sound.
- A wide sweet spot is best for great sound.
- Bass is non-directional, so exact woofer placement and orientation isn’t critical.
- Bass is non-directional, so only one sub is required.
- The best speaker drivers must be low-mass.
- A “fast” bass driver is superior to others.
- The best sounding systems are dead quiet.
- Granite makes a great isolation material.
- Cones & spikes provide isolation.
- Wide dispersion is desirable for consumer audio loudspeakers.
- An equilateral triangle (speakers and listening seat) set-up yields great sound.
- The best bi-amplification is done with transistors on bass, tubes on top.
- Achieving the tightest bass should be your goal.
- Speaker set-up diagrams/guides from various manufacturers will provide the best sound.
- There are several known “good” listening room sizes/dimensions.
- Building a new listening room with a good spread-sheet program will provide great sound.
- If you’re past 50, you can no longer hear well enough to really care about your sound quality.
- And others, equally as revered, and equally as questionable (once you know the facts).
Fonte:
Barone Rosso- Moderatore
Re: Miti audiofili da sfatare
Alcuni che mi sorprendono:
"Bass is non-directional"
"The best sounding systems are dead quiet" (E allora rinforzi vari delle casse +antirombo & co.??)
"Achieving the tightest bass should be your goal" (E pasta x lavelli sui driver?)
Numero di messaggi : 2616
Impianto : Cresce... ;-]]
Vi metto anche la traduzione fatta con google:
Traduzione con google ha scritto:Traduzione da Inglese verso Italiano
Camere con pareti non parallele suono migliore.
La "regola dei terzi" è una grande guida set-up.
massimali Cattedrale di fornire un suono eccezionale.
Una macchia larga dolce che è meglio per un suono eccezionale.
Il basso è non direzionale, l'inserimento di woofer in modo esatto e
l'orientamento non è critica.
Il basso è non-direzionale, in modo che solo un sub è necessario.
I piloti migliori diffusore deve essere di piccola massa.
Un "driver" fast basso è superiore agli altri.
I migliori sistemi di suono sono morti tranquilla.
Granito fa un ottimo materiale di isolamento.
Coni e picchi di fornire isolamento.
larga dispersione è auspicabile per l'audio dei consumatori
altoparlanti.
Un triangolo equilatero (altoparlanti e di ascolto del sedile) set-
la resa audio eccellente.
Il miglior bi-amplificazione è fatto con transistor al basso,
tubi in alto.
Ottenere il più strette basso dovrebbe essere il vostro obiettivo.
diagrammi Speaker set-up / guide di diversi produttori
fornirà il suono migliore.
Ci sono molti noti camera "buon ascolto
dimensioni / dimensioni.
Costruire una nuova sala d'ascolto con una buona diffusione fogli
programma prevede un grande suono.
Se siete ultimi 50, non si può più sentire abbastanza bene per
veramente a cuore la qualità del suono.
E altri, altrettanto venerato, e altrettanto discutibili
(Una volta che conoscete i fatti).
Claudio Arzani ha scritto:Alcuni che mi sorprendono:
Sui bassi non direzionali ci sarebbe molto da dire ....
Nel secondo caso non si riferisce alle casse ma al locale di ascolto, l'autore è contrario ai locali troppo neutri.
Anche in questo caso dice che un impianto deve suonare bene dai 10 Hz ai 20 KHz.
10 hz? E magari flat eh? in un ambiente grande quanto un campo sportivo!
piero7- Membro classe oro
piero7 ha scritto:10 hz? E magari flat eh? in un ambiente grande quanto un campo sportivo!
Certo piattissimo
Ma in principio dice che l'obbiettivo non devono essere solo i bassi ...
C'era un sito on line per il calcolo del posizionamento dei diffusori in base alla altezza, cubatura della stanza, divani, mobilia, tappeti, sedie, pavimento, davvero
ben fatto.
Ho provato a metterli dove dicevano loro e a considerarlo un buon punto di partenza,
ma in realtà il calcolo portava a risultati molto lontani dall'ottimale, quindi l'unica è
provare.
Da me i diffusori posizioni a triangolo equilatero non vanno, vanno molto meglio a isoscele, ogni ambiente fa storia a se.
Il bello è che sia le torri che ho usato e quelle che ora sto usando gradiscono la medesima posizione, le une erano reflex e le altre a sospensione pneumatica.
Anche le arbour da scaffale che ho avuto gradivano la stessa posizione delle torri che ho adesso.
ben fatto.
provare.
Massimo- Membro classe bronzo
Numero di messaggi : 1999
Provincia : Macerata
Massimo ha scritto:C'era un sito on line per il calcolo del posizionamento dei diffusori in base alla altezza, cubatura della stanza, divani, mobilia, tappeti, sedie, pavimento, davvero
ben fatto.
provare.
questo la dice lunga su quale accordo è migliore...
Fonte:
Che queste siano puttanate, è piuttosto evidente....
porfido- Membro classe oro
Questo non è falso, dipende dalle dimensioni del driver. Ma in generale è corretta.
Dipende da quale SS e quale tubo
Telstar- Membro classe bronzo
Numero di messaggi : 1717
Telstar ha scritto:The best speaker drivers must be low-mass.
che belli sti comandamenti del buon audiofilo ... io sono eretico pero' ...
Diciamo di si anche se fattori importati IMHO sono il BxL e il CMS per giudicare un buon low driver
» Diffusori e ambiente
» Sbocco reflex e credenze da sfatare
» TV per audiofili?
» Lotto 79 cd I miti del Rock 120 euro
» Considerazioni generali, tra miti e leggende
» TV per audiofili?
