Driver Asio e foobar
+6
daniele
Dreamflyer
metalzone84
10 partecipanti
Pagina 3 di 5
Pagina 3 di 5 • 1, 2, 3, 4, 5
Re: Driver Asio e foobar
Wasky, ma la emu 0404 è compatibile con SO Vista? Qui leggo che è compatibile con SO XP =>
http://www.emu.com/products/product.asp?category=610&subcategory=611&product=15185&nav=technicalSpecifications
metalzone84- Interessato
- Data d'iscrizione : 12.11.10
Numero di messaggi : 65
Impianto : Scythe
metalzone84 ha scritto:Wasky, ma la emu 0404 è compatibile con SO Vista? Qui leggo che è compatibile con SO XP =>
C'è la versione dei driver sia per Vista E-MU® 0202 / 0404 / Tracker Pre USB Web Install Package v1.3
http://www.emu.com/support/files/download2.asp?Centric=1004&Legacy=0&Platform=1
che per Seven cosi finalmente non si usano più quelli di Vista per le ottime schede EMU
Release per Schede PCI e PCI Ex
http://connect.creativelabs.com/emu/Files/EmuPMX_PCDrv_US_2_30_00_BETA.zip
Release per Schede USBE-MU is pleased to announce that we are providing a public Beta driver for all current E-MU PCI/PCI products for use in Windows XP, Windows Vista and Windows 7 32-Bit & 64-Bit versions.
Applies to: 0404 PCI/PCIe, 1212M PCI/PCIe, 1616/1616M PCI/PCIe
** Download is an executable file that contains just the driver. Works with PatchMix v2.1 or greater. You should be able to run it and install it over the top of any existing driver version.
** Some XP users may get asked for permission to replace/overwrite two files. Allow the files to be replaced.
** While this driver should also work for legacy products such as the E-MU 1820, 1820M, 1212 v1, Sync Daughter card and the 02 CardBus PCMCIA card, they have not been tested. These are all discontinued products and will no longer be part of any new software or hardware development nor will they have any further specific updates.
** There is no official support for this Beta driver. Your feedback on this Beta driver is desired and welcome. Contact us via our support email system and select Windows 7 Beta Driver or Windows 7 Beta Driver x64 for the Operating System platform at:
http://connect.creativelabs.com/emu/Files/EMUU_PCAppDrv_US_1_40_00_BETA.zip
E-MU is pleased to announce that we are providing a public Beta driver for all current E-MU USB Audio Interface products for use in Windows XP, Windows Vista and Windows 7 32-Bit & 64-Bit versions.
Applies to: 0202 USB, 0404 USB, Tracker Pre USB
** Download is an executable installer file that contains both the E-MU USB Control Panel and the new Beta driver.
** Please refer to the ReadMe file in the installer package for specifics on this Beta driver.
** There is no official support for this Beta driver. Your feedback on this Beta driver is desired and welcome. Contact us via our support email system and select Windows 7 Beta Driver or Windows 7 Beta Driver x64 for the Operating System platform. E-MU Technical Support is at:
Preciso e dettagliato come sempre...ti ringrazio per il grande aiuto che mi stai dando!
A questo punto propenderei appunto per questa scheda audio esterna...e per leggere i cd cosa mi consigli?
Impianto : Scythe
metalzone84 ha scritto:Preciso e dettagliato come sempre...ti ringrazio per il grande aiuto che mi stai dando!
Ma ci mancherebbe è un piacere
La stessa scheda la possiede un utente di audioreview e ne è entusiata
Per leggere i CD puoi usare il NB oppure ne fai una immagine NRG e la monti su Daemon tools ma, ti conviene ripparli in FLAC level 2 e tenerli in storage su un HDD esterno
Puoi cmq usare sempre foobar2000 per leggerli
Roberto
Ok wasky!
Ma poi la scheda audio interna la devo disattivare? O non è necessario?
Dato che poi non potrei ascoltare musica senza aver collegato il notebook al sistema.
Impianto : Scythe
wasky ha scritto:
se prendi la EMU non hai nessun bisogno di un DAC mentre, se un giorno volessi accoppiare un DAC al Setup comprensivo di EMU lo potresti interfacciare alla uscita SPDIF della EMU ma, serve un buon DAC visto che la EMU brucia il sederino bello a DAC da 2000 € e oltre
Ma è vera 'sta cosa?
Interessante!
Numero di messaggi : 1475
Wasky cosa ne pensi della TerraTec DMX 6 Fire che costa ugualmente 200 euro?
■USB 2.0 audio system
■1 microphone input with gain control (combo XLR / 6.3 mm jack)
■48V phantom power
■20 dB pad switch
■1 instrument input with gain control (6.3 mm jack)
■4 analogue inputs (cinch)
■1 phono input (RCA cinch) with RIAA equalizer and gain control
■6 analogue outputs (cinch)
■Stereo to 5.1 Surround Expander
■1 headphone jack (6.3 mm) with separate volume controller
■1 optical digital input/output (TOS Link)
■1 coaxial digital input/output (cinch)
■1 MIDI interface In/Out (5-pin DIN)
■24 bit / 192 kHz A/D converter with 114 dB (A) SNR* (input 1/2)
■24 bit / 192 kHz A/D converter with 105 dB (A) SNR* (input 3/4)
■24 bit / 192 kHz D/A converter with 114 dB (A) SNR* (outputs 1-6)
■48V phantom power
■20 dB pad switch
Impianto : Scythe
metalzone84 ha scritto:Wasky cosa ne pensi della TerraTec DMX 6 Fire che costa ugualmente 200 euro?
■48V phantom power
■20 dB pad switch
Terratec mi colpi con la phase24 prof ma, questa non l'ho mai provata, ottimo il router delle uscite e ha il supporto ASIO ma, non saprei dirti che DAC usa per la conversione D/A
Scusa per la risposta in ritardo
Ma figurati!
E secondo le specifiche tecniche la ritieni inferiore o superiore alla e-mu 0404?
Impianto : Scythe
metalzone84 ha scritto:Ma figurati!
ogni DAC ha un suo suono e dipende anche dalla circuitazione senza sentirle entrambe, è difficile dire quale sia meglio
EMU è una sicurezza
Ok grazie mille! Propendo per la e-mu, mi resta da decidere solo se prendere la tracker pre o la 0404...ma forse con 30 euro in più mi conviene la 0404...che dici?
Cerco di comprarla da qualche negozio qui a Milano, così è più facile in caso di guasti o garanzia.
Impianto : Scythe
metalzone84 ha scritto:Ok grazie mille! Propendo per la e-mu, mi resta da decidere solo se prendere la tracker pre o la 0404...ma forse con 30 euro in più mi conviene la 0404...che dici?
C'è un grosso Negozio di Strumenti musicali a Milano che sò per certo è fornitissimo ma, mi sfugge il nome ora
Io ho avuto la tracker Pre poi rivenduta ad un utente del forum, considera che ci progettano diffusori da molti $ e viene consigliata anche dalla spectral plus per il suo software di misura
Se prendi la EMU 0404 guadagni il coax Digitale
Intendi lucky music??? Ho controllato sul loro sito ma non possiedono nessuna delle due e-mu.
Che utilizzo potrei farne del coax digitale?
Impianto : Scythe
metalzone84 ha scritto:Intendi lucky music??? Ho controllato sul loro sito ma non possiedono nessuna delle due e-mu.
Si esatto è quello lo shop me ne parlano sempre bene Metalzone
Utilizzo del Coassiale
Se prendi un buon CDP come meccanica, potresti usare lei come DAC connettendocelo e funziona anche senza accendere il PC
Roberto
io ho avuto la 0202..suonava benissimo era solo usb però;
daniele- Membro classe bronzo
Numero di messaggi : 1740
Provincia : vp
Impianto : Hegel h190
Leak Stereo 20
Thorens td124
DAC Lampizator
Dynaudio sp40
Capito! Allora alla ricerca della e-mu 0404 qui a Milano.wasky ha scritto:metalzone84 ha scritto:Intendi lucky music??? Ho controllato sul loro sito ma non possiedono nessuna delle due e-mu.
Roberto
Impianto : Scythe
Wasky ho ancora bisogno del tuo aiuto!
Ho comprato la e-mu 0404, collegata al NB tramite usb e all'ampli tramite cavo stereo piccolo (x intenderci quello per l'output del suono di qualsiasi notebook)...è impostata automaticamente per lavorare a 96 khz...ma quando ascolto musica sento degli schiocchi provenienti dai diffusori.
Da cosa potrebbe dipendere? Forse dovrei uscire dalla scheda audio con due cavi, maschio e femmina...anzichè quello singolo piccolo?
Impianto : Scythe
metalzone84 ha scritto:Wasky ho ancora bisogno del tuo aiuto!
No non usare il main ma i due TRS Out Left e Right trovi i cavi già pronti anche da Lucky Music
Ricapitoliamo cosi analizziano
Prima di tutto vediamo le DPC del tuo PC scarica questo SW e mandalo in esecuzione
http://www.thesycon.de/deu/latency_check.shtml
Hai settato quale Output su Foobar2000 ?
Roberto
Questi due cavi TRS Out Left e Right non li ho, magari oggi passo da pc city e controllo se li hanno lì.
Su foobar ho provato tutte le combinazioni, molte non funzionano, altre si sentono male.
Forse devo cambiare qualcosa in pannello di controllo/audio???
Questo programma mentre analizza al centro mi dice:
Some device drivers on this machine behave bad and will probably cause drop-outs in real-time audio and/or video streams. To isolate the misbehaving driver use device manager and disable/re-enable various devices, one at a time. Try network and w-lan adapters, modems, internal sound devices, usb host controllers, etc.
Impianto : Scythe
metalzone84 ha scritto:Questi due cavi TRS Out Left e Right non li ho, magari oggi passo da pc city e controllo se li hanno lì.
Non è un cavo che trovi nei negozi di PC ma, in quelli di strumenti ti serve un cavo Jack mono 6.3 @ RCA
http://www.strumentimusicali.net/product_info.php/cPath/35_70_318/products_id/7441/cavi-rca/proel-die-hard-cavo-2-jack-mono-6,3---2-rca-3mt.-%5Bdh535lu3%5D.html
Devi usare su Seven o WASAPI oppure ASIO ma, devi creare un profilo su foobar
Se DPC Latency ti dice cosi abbiamo risolto il problema degli scrocchi hai un NB che non è buono per Audio o va ottimizzato
Crea un profilo ASIO e prova con quell'output
http://www.nexthardware.com/forum/computer-audio-hi-fi/66785-foobar2000-creare-profilo-asio-e-resample.html
Allora wasky per quanto riguarda configurare l'asio e il resample l'ho fatto su foobar. Però i problemi persistono.
Per quanto riguarda il notebook non penso che siano problemi di potenzialità, anche xchè sorpassa di tanto i requisiti della scheda audio.
Io comunque adesso per semplificare le cose ho collegato alla scheda audio delle casse x pc amplificate bose.
Impianto : Scythe
metalzone84 ha scritto:Per quanto riguarda il notebook non penso che siano problemi di potenzialità, anche xchè sorpassa di tanto i requisiti della scheda audio.
Non è un problema di HW ma, di SW e di Deferred Procedure Call se ne parla qui
http://t-class.niceboard.org/digital-audio-workstation-f50/il-mio-htpc-t11610-15.htm
Che valore ottieni su DPC Latency ?
sui 1000 in tutti i campi
Ho provato a disconnettere l'usb...e a lanciare il programma dpc latency ma il parametri sono gli stessi.
Cosa mi consigli di fare?
Impianto : Scythe
Ho preso i cavi e collegati...stesso problema. Ci sono dei picchi di latenza (segnati in rosso) che mi producono degli schiocchi...strano però che quando ascolto con l'audio del NB non li sento!
Impianto : Scythe
Sono riuscito a ridurre i picchi rossi disabilitando alcune periferiche da gestione dispositivi, ma comunque i risultati di latenza si mantengono gialli (più o meno sui 1000).
Impianto : Scythe
» HifiMeDiy Sabre USB DAC
» Aiuto per prima configurazione Foobar e driver ASIO
» aggiornamento driver asio
» Driver scheda o ASIO/KS
» I migliori driver ASIO da AQVOX?
Pagina 3 di 5
Oggi alle 10:42 Da MaxBar
Oggi alle 10:37 Da Chardonnay
Oggi alle 10:24 Da philball1959
Oggi alle 7:03 Da Spoons965
Ieri alle 15:41 Da ste-65
Ieri alle 12:47 Da jenw84
Ieri alle 8:54 Da RF14381
» Problema audio tv
» lenco l 75
» lenco l 75
» jbl Radiance 121 VX
» Nuovo Eversolo DMP A-10
