schermatura pre con cabinet legno
Andrea Zani
valvolas
Luigi.Mzzl
Pagina 2 di 2
Pagina 2 di 2 • 1, 2
Re: schermatura pre con cabinet legno
Se ben ricordo c'è anche chi sostiene che la schermatura è dannosa perché trattiene (riflette?) i disturbi all'interno del cabinet...
EDIT: ricordavo bene:
https://www.tforumhifi.com/t12867p270-nva-diego-nardi-e-gli-audioti#202677
Regarding metal, every manufacturer has his ideas and foibles, they may be right and they may be wrong, but there is an English expression "that the proof of a pudding is in the eating", so it is very easy to see if you agree with my design choices, and that is buy an amplifier, and if you don't like my choices send it back for a refund. Anyway there is lots of metal in the amplifier, as every component has metal leads, every wire is made of metal, PCB tracks are metal, even solder is metal, heatsink has to be metal, all of those are unavoidable and good. All I object to is ferrous cases that contain the field generated by circuits and transformers. If a field is blocked it doesn't dissipate it reflects and mixes with new field and creates harmonic patterns that interfere with the music. It is much better to let the field out to dissipate naturally. This makes the unit more susceptible to field getting in, but this is only a problem with a phono amplifier.
Switters- Membro classe oro
Numero di messaggi : 5072
sasachess ha scritto:valvolas ha scritto:
1) la schermatura è si consigliabile ma NON la prescrive il medico (io sul ta2020 case legno nn l'ho fatta e lavora benissimo senza EMI)
Sicuro al 100%? Lo hai misurato il tuo ta2020?
lo so :SAREBBE meglio,e a titolo personale lo farei internamente con le lattine della coca aperte o lamierino modellato magari a ''isole'',ma visto che ha/avrebbe (x la persona interessata) limiti estetici nn è che vedo molte soluzioni.
No nn ho fatto misure ma nn le ''sento'' le interferenze,se avessi qlc a valvole mi sarei cautelato di piu' trattandosi di un T-amp me ne sono un po' fregato,il mio ternmine di riscontro si ferma li.Se accendi un misuratore di radioattività e guardi il ''fondo'' saresti sorpreso di come già nn siamo già ''bolliti'' tutti.
Il tappo è uno di quegli affari circolari o quadrati che si mettono al muro dove ci sono apparecchi a gas x dare aria all'esterno,oppure quelli che vedevi nelle scansie dei mobili vecchi della cucina (meglio nn te lo so spiegare),di solito sono circolari di lamierino o di plastica li ho visti anche di rame.Io li ho trovati al reparto ferramenta.
http://www.areazione.eu/griglie_di_areazione/griglie_sicurezza/griglia_areazione_W15R.htm
Ultima modifica di valvolas il Gio 20 Ott 2011 - 18:32 - modificato 1 volta.
valvolas- Membro classe oro
Numero di messaggi : 5253
ah certo certo, ovviamente faccio in modo che arieggi bene (ma di certo non è un termosifone questo piccolo pre, suppongo)
magari per essere sicuro della cosa, mi direste per favore quello che devo sapere per effettuare una buona schermatura? non intendo sui materiali (di quello abbiamo più o meno discusso) ma del collegamento, posizione dela schermatura, cosa conviene schermare maggiormente.......................................................
Numero di messaggi : 1894
da qlc parte nel forum c'e' una discussione su cm fare un buon centro stella,fatta da uno in gamba in ste cose leggiti quella,perchè nn è semplicissimo almeno le prime volte, bisogna rispettare dei canoni di collegamento x evitare ''ritorni''.Per le schermature dovresti proteggere le parti irradiabili/che irradiano con lamiera (di solito riflettente) intorno alle skede interessate.Una gabbia intera sarebbe meglio ma dovresti costruire in pratica un case nel case...
non so se può essere utile, ma il pre di maurarte ha tutte le masse in comune...
come posso realizzare quindi la schermatura?
mettiamo che la devo fare con dei pezzi di alluminio da fissare all'interno al legno
devo decidere anche in che punti collegare i pezzi di alluminio? cambia qualcosa?
adesso direi che vi romperò le scatole per imparare a schermare ahahahhahha
trovato leggiti questa:
https://www.tforumhifi.com/t7559-regole-contro-il-loop-di-massa?highlight=loop+di+massa
ps Non sottovalutare il problema termico se usi il plexiglass sul tetto usa un tappo a griglie o l'aria calda ristagna dentro non c'e' solo il rischio fuoco.(il case è di legno che è da sempre un combustibile) ma i semiconduttori hanno un brutto vizio:oltre una certa temperatura vanno ''in deriva'' e non lavorano piu' come prima,del resto come dico sempre:anche loro (i semiconduttori) sono generosi ma nn sono pirla dopo un po al caldo nn reggono,e si arrendono...
letto, ti ringrazio!!! ^_^valvolas ha scritto:trovato leggiti questa:
ora però già che ci sono vi faccio un paio di domandine ihihihih xD
le masse delle rca e del potenziometro in quali punti devono essere collegate? c'è differenza?
e il potenziometro avendo il frontale in metallo deve essere a contatto con il frontale schermato o lo devo isolare?
ragazzi adesso ho base e lati in alluminio da 1mm ^^
la parte anteriore viene fatta solo in legno, e la posteriore idem
all'interno utilizzo delle lastre di ferro sottili per schermare il trasformatore dal resto e in generale la sezione alimentazione dalla scheda
il mio no.........robertor ha scritto:alcuni trasformatori hanno le calotte.
le calotte le vendono separatamente,a formati.....Io nn ricordo pero' dove le ho viste
» Restauro totale Jbl L100 Century
» Fabbrica produzione cabinet in legno per progetti diffusori ed altro
» Cabinet Intelligente
» Schermatura rca
» Lamierino per schermatura
» Schermatura rca
Pagina 2 di 2
Ieri alle 15:41 Da ste-65
Ieri alle 13:08 Da mauretto
Ieri alle 12:47 Da jenw84
Ieri alle 8:54 Da RF14381
» Problema audio tv
» lenco l 75
» lenco l 75
» jbl Radiance 121 VX
» Nuovo Eversolo DMP A-10
» Switch - Preamp
