Raspyfi: raspberry pi + voyage mpd. Progetto per un ottima sorgente low cost
+35
toti
cordering
burmar
fuzzu82
pierpabass
3RTDT
Dexterdm
turo91
tomJobim
Andrea Zani
grunter
marcomosso
sasachess
tino84
davide66
Wordcrasher
alluce
vadopertentativi
slystoner
romvise
Alessio Zenga
masmau
pippo1999
kurt10
Luca brh
sontero
Miclaud
traspar
cavicchi
Menestrello
mikelangeloz
39 partecipanti
Pagina 19 di 35 Precedente  1 ... 11 ... 18, 19, 20 ... 27 ... 35  Successivo
Raspyfi: raspberry pi + voyage mpd. Progetto per un ottima sorgente low cost - Pagina 19 Empty Re: Raspyfi: raspberry pi + voyage mpd. Progetto per un ottima sorgente low cost
Messaggio Da sontero Gio 31 Gen 2013 - 15:03
questo e' il file mpd.conf
Codice:
# An example configuration file for MPD
# See the mpd.conf man page for a more detailed description of each parameter.
# Files and directories #######################################################
# This setting controls the top directory which MPD will search to discover the
# available audio files and add them to the daemon's online database. This
# setting defaults to the XDG directory, otherwise the music directory will be
# be disabled and audio files will only be accepted over ipc socket (using
# file:// protocol) or streaming files over an accepted protocol.
#music_directory                "/mnt/nas"
music_directory        "/media/musica1"
# This setting sets the MPD internal playlist directory. The purpose of this
# directory is storage for playlists created by MPD. The server will use
# playlist files not created by the server but only if they are in the MPD
# format. This setting defaults to playlist saving being disabled.
playlist_directory              "/var/lib/mpd/playlists"
# This setting sets the location of the MPD database. This file is used to
# load the database at server start up and store the database while the
# server is not up. This setting defaults to disabled which will allow
# MPD to accept files over ipc socket (using file:// protocol) or streaming
# files over an accepted protocol.
db_file                "/var/lib/mpd/tag_cache"
# These settings are the locations for the daemon log files for the daemon.
# These logs are great for troubleshooting, depending on your log_level
# settings.
# The special value "syslog" makes MPD use the local syslog daemon. This
# setting defaults to logging to syslog, otherwise logging is disabled.
log_file                        "/var/log/mpd/mpd.log"
# This setting sets the location of the file which stores the process ID
# for use of mpd --kill and some init scripts. This setting is disabled by
# default and the pid file will not be stored.
pid_file                        "/var/run/mpd/pid"
# This setting sets the location of the file which contains information about
# most variables to get MPD back into the same general shape it was in before
# it was brought down. This setting is disabled by default and the server
# state will be reset on server start up.
state_file                      "/var/lib/mpd/state"
# The location of the sticker database.  This is a database which
# manages dynamic information attached to songs.
sticker_file                  "/var/lib/mpd/sticker.sql"
# General music daemon options ################################################
# This setting specifies the user that MPD will run as. MPD should never run as
# root and you may use this setting to make MPD change its user ID after
# initialization. This setting is disabled by default and MPD is run as the
# current user.
user                            "mpd"
# This setting specifies the group that MPD will run as. If not specified
# primary group of user specified with "user" setting will be used (if set).
# This is useful if MPD needs to be a member of group such as "audio" to
# have permission to use sound card.
group                          "nogroup"
# This setting sets the address for the daemon to listen on. Careful attention
# should be paid if this is assigned to anything other then the default, any.
# This setting can deny access to control of the daemon. Choose any if you want
# to have mpd listen on every address
# For network
bind_to_address        "any"
# And for Unix Socket
#bind_to_address                "/var/run/mpd/socket"
# This setting is the TCP port that is desired for the daemon to get assigned
# to.
#port                          "6600"
# This setting controls the type of information which is logged. Available
# setting arguments are "default", "secure" or "verbose". The "verbose" setting
# argument is recommended for troubleshooting, though can quickly stretch
# available resources on limited hardware storage.
#log_level                      "default"
# If you have a problem with your MP3s ending abruptly it is recommended that
# you set this argument to "no" to attempt to fix the problem. If this solves
# the problem, it is highly recommended to fix the MP3 files with vbrfix
# (available as vbrfix in the debian archive), at which
# point gapless MP3 playback can be enabled.
#gapless_mp3_playback                  "yes"
# This setting enables MPD to create playlists in a format usable by other
# music players.
#save_absolute_paths_in_playlists      "no"
# This setting defines a list of tag types that will be extracted during the
# audio file discovery process. Optionally, 'comment' can be added to this
# list.
#metadata_to_use        "artist,album,title,track,name,genre,date,composer,perf$
# This setting enables automatic update of MPD's database when files in
# music_directory are changed.
auto_update    "yes"
# Limit the depth of the directories being watched, 0 means only watch
# the music directory itself.  There is no limit by default.
#auto_update_depth "3"
# Symbolic link behavior ######################################################
# If this setting is set to "yes", MPD will discover audio files by following
# symbolic links outside of the configured music_directory.
#follow_outside_symlinks        "yes"
# Zeroconf / Avahi Service Discovery ##########################################
# If this setting is set to "yes", service information will be published with
# Zeroconf / Avahi.
#zeroconf_enabled              "yes"
# The argument to this setting will be the Zeroconf / Avahi unique name for
# this MPD server on the network.
#zeroconf_name                  "Music Player"
# Permissions #################################################################
# If this setting is set, MPD will require password authorization. The password
# can setting can be specified multiple times for different password profiles.
#password                        "password@read,add,control,admin"
# This setting specifies the permissions a user has who has not yet logged in.
#default_permissions            "read,add,control,admin"
# Input #######################################################################
input {
        plugin "curl"
#      proxy "proxy.isp.com:8080"
#      proxy_user "user"
#      proxy_password "password"
# Audio Output ################################################################
# MPD supports various audio output types, as well as playing through multiple
# audio outputs at the same time, through multiple audio_output settings
# blocks. Setting this block is optional, though the server will only attempt
# autodetection for one sound card.
# See <http://mpd.wikia.com/wiki/Configuration#Audio_Outputs> for examples of
# other audio outputs.
# An example of an ALSA output:
audio_output {
        type            "alsa"
        name            "Luckit USB Audio 2.0"
        device          "hw:0,0"        # optional
        format          "44100:16:2"    # optional
#      mixer_device    "software"      # optional
#      mixer_control  "PCM"          # optional
#      mixer_index    "0"            # optional
# An example of an OSS output:
#audio_output {
#      type            "oss"
#      name            "My OSS Device"
#      device          "/dev/dsp"      # optional
#      format          "44100:16:2"    # optional
#      mixer_device    "/dev/mixer"    # optional
# An example of a shout output (for streaming to Icecast):
#audio_output {
#      type            "shout"
#      encoding        "ogg"                  # optional
#      name            "My Shout Stream"
#      host            "localhost"
#      port            "8000"
#      mount          "/mpd.ogg"
#      password        "hackme"
#      quality        "5.0"
#      bitrate        "128"
#      format          "44100:16:1"
#      protocol        "icecast2"              # optional
#      user            "source"                # optional
#      description    "My Stream Description" # optional
#      genre          "jazz"                  # optional
#      public          "no"                    # optional
#      timeout        "2"                    # optional
# An example of a recorder output:
#audio_output {
#      type            "recorder"
#      name            "My recorder"
#      encoder        "vorbis"                # optional, vorbis or lame
#      path            "/var/lib/mpd/recorder/mpd.ogg"
##      quality        "5.0"                  # do not define if bitrate is d$
#      bitrate        "128"                  # do not define if quality is d$
# An example of a httpd output (built-in HTTP streaming server):
#audio_output {
#      type            "recorder"
#audio_output {
#      type            "httpd"
#      name            "My HTTP Stream"
#      port            "8000"
# An example of a pulseaudio output (streaming to a remote pulseaudio server)
#audio_output {
#      type            "pulse"
#      name            "My Pulse Output"
#      server          "remote_server"        # optional
#      sink            "remote_server_sink"    # optional
## Example "pipe" output:
#audio_output {
#      type            "pipe"
#      name            "my pipe"
#      command        "aplay -f cd 2>/dev/null"
## Or if you're want to use AudioCompress
#      command        "AudioCompress -m | aplay -f cd 2>/dev/null"
## Or to send raw PCM stream through PCM:
#      command        "nc example.org 8765"
## An example of a null output (for no audio output):
#audio_output {
#      type            "null"
#      name            "My Null Output"
# This setting will change all decoded audio to be converted to the specified
# format before being passed to the audio outputs. By default, this setting is
# disabled.
#audio_output_format            "44100:16:2"
# If MPD has been compiled with libsamplerate support, this setting specifies
# the sample rate converter to use.  Possible values can be found in the
# mpd.conf man page or the libsamplerate documentation. By default, this is
# setting is disabled.
#samplerate_converter          "Fastest Sinc Interpolator"
# Volume control mixer ########################################################
# These are the global volume control settings. By default, this setting will
# be detected to the available audio output device, with preference going to
# hardware mixing. Hardware and software mixers for individual audio_output
# sections cannot yet be mixed.
# An example for controlling an ALSA, OSS or Pulseaudio mixer; If this
# setting is used other sound applications will be affected by the volume
# being controlled by MPD.
#mixer_type                    "hardware"
# An example for controlling all mixers through software. This will control
# all controls, even if the mixer is not supported by the device and will not
# affect any other sound producing applications.
#mixer_type                    "software"
# This example will not allow MPD to touch the mixer at all and will disable
# all volume controls.
#mixer_type                    "disabled"
# Normalization automatic volume adjustments ##################################
# This setting specifies the type of ReplayGain to use. This setting can have
# the argument "album" or "track". See <http://www.replaygain.org> for more
# details. This setting is disabled by default.
#replaygain                    "album"
# This setting sets the pre-amp used for files that have ReplayGain tags. By
# default this setting is disabled.
#replaygain_preamp              "0"
# This setting enables on-the-fly normalization volume adjustment. This will
# result in the volume of all playing audio to be adjusted so the output has
# equal "loudness". This setting is disabled by default.
#volume_normalization          "no"
# MPD Internal Buffering ######################################################
# This setting adjusts the size of internal decoded audio buffering. Changing
# this may have undesired effects. Don't change this if you don't know what you
# are doing.
audio_buffer_size              "2048"
# This setting controls the percentage of the buffer which is filled before
# beginning to play. Increasing this reduces the chance of audio file skipping,
# at the cost of increased time prior to audio playback.
buffer_before_play              "10%"
# Resource Limitations ########################################################
# These settings are various limitations to prevent MPD from using too many
# resources. Generally, these settings should be minimized to prevent security
# risks, depending on the operating resources.
#connection_timeout            "60"
#max_connections                "10"
#max_playlist_length            "16384"
#max_command_list_size          "2048"
#max_output_buffer_size        "8192"
# Character Encoding ##########################################################
# If file or directory names do not display correctly for your locale then you
# may need to modify this setting. After modification of this setting mpd
# --create-db must be run to change the database.
filesystem_charset              "UTF-8"
# This setting controls the encoding that ID3v1 tags should be converted from.
id3v1_encoding                  "UTF-8"
# SIDPlay decoder #############################################################
# songlength_database:
#  Location of your songlengths file, as distributed with the HVSC.
#  The sidplay plugin checks this for matching MD5 fingerprints.
#  See http://www.c64.org/HVSC/DOCUMENTS/Songlengths.faq
# default_songlength:
#  This is the default playing time in seconds for songs not in the
#  songlength database, or in case you're not using a database.
#  A value of 0 means play indefinitely.
# filter:
#  Turns the SID filter emulation on or off.
#decoder {
#      plugin                  "sidplay"
#      songlength_database    "/media/C64Music/DOCUMENTS/Songlengths.txt"
#      default_songlength      "120"
#      filter "true"
sontero
sontero
Data d'iscrizione : 23.06.12
Numero di messaggi : 498
Provincia : Cagliari
Impianto : Sorgente :
Messaggio Da mikelangeloz Gio 31 Gen 2013 - 15:06
Prova a cambiare
in
device "hw:1,0" # optional
mikelangeloz
mikelangeloz
Data d'iscrizione : 11.08.11
Numero di messaggi : 1008
Provincia : Come fosse Antani
https://volumio.org
Messaggio Da sontero Gio 31 Gen 2013 - 15:18
mikelangeloz ha scritto:Prova a cambiare
in
Allora mike prima era "hw:1,0" e non mi dava alsamixer . L'ho cambiato in "hw:0,0" e cosi invece alsamixer si presenta
cioe' cosi :
Raspyfi: raspberry pi + voyage mpd. Progetto per un ottima sorgente low cost - Pagina 19 Alsa_b10
sontero
sontero
Messaggio Da sontero Ven 1 Feb 2013 - 0:25
Allora Mike dopo aver smanettato come un ossesso sul file "mpd.conf " alla fine son riuscito a far partire mpd .
che fatica... che dire ...almeno un altro scoglio e' superato . La WaveIO funge (cominciavo a dubitare anche su di lei)
l'ascolto e' stato breve e devo dire non e' male . ho percepito pernacchiette fugaci ma magari su questo punto spero tu mi possa dare supporto.
magari la prossima release spero sia un passo avanti
comunque sono contento almeno so che l'ambaradan puo' funzionare
non capisco bene perche' ma alla fine ho messo nel mpd.conf cosi :
audio_output {
type "alsa"
name "USB DAC"
Magari se vuoi riposto il file mpd.conf come e' adesso
grazie ancora
sontero
sontero
Messaggio Da alluce Ven 1 Feb 2013 - 11:25
sontero ha scritto:Allora Mike dopo aver smanettato come un ossesso sul file "mpd.conf " alla fine son riuscito a far partire mpd .
audio_output {
type "alsa"
name "USB DAC"
grazie ancora
se senti le pernacchiette prova
device "plughw:1,0" # optional
è un po' meno bitperfect ma a volte è preferibile
alluce
alluce
Data d'iscrizione : 12.03.12
Numero di messaggi : 1158
Provincia : splendida
Impianto : casa:
Messaggio Da mikelangeloz Ven 1 Feb 2013 - 12:24
Togli il commento da
E' un pò complicata la storia di alsamixer... Ma tanto non ti serve perchè puoi regolare il volume direttamente da client!
mikelangeloz
mikelangeloz
https://volumio.org
Messaggio Da vadopertentativi Sab 2 Feb 2013 - 10:22
Mikelangeloz, secondo te l' Odac XL (in pratica la versione con led e sia rca che jack) può avere problemi di alimentazione con il raspberry pi? Che faccio, ordino???
vadopertentativi
Data d'iscrizione : 30.12.12
Numero di messaggi : 22
Messaggio Da davide66 Sab 2 Feb 2013 - 13:07
Ciao Michelangeloz, sto seguendo il tuo progetto e sono molto soddisfatto dei risultati, complimenti!
Adesso ho un problema con il collegamento ad un NAS (con l'hard disk usb collegato al raspberry funziona tutto)... Infatti seguendo la tua guida e modificando il fstab non riesco a vedere i files..come se fosse sbagliato il collegamento. Dagli altri computer della rete la cartella Musica si vede mentre dal raspberry no..
C'è un modo per capire come il raspberry vede i collegamenti? Scusa ma sono scarsissimo con linux!
Davide
davide66
Data d'iscrizione : 29.12.12
Numero di messaggi : 8
Messaggio Da sontero Sab 2 Feb 2013 - 13:49
ciao Mike
mi sto godendo la macchinetta.
Suona bene .
ho eseguito quanto da te suggerito cioe' decommentare "format "44100:16:2" # optional".
Va' meglio ma ci sono ancora disturbi , meno frequenti ma ci sono .
Che ne pensi . Si puo' fare meglio??
sontero
sontero
Messaggio Da mikelangeloz Sab 2 Feb 2013 - 14:20
vadopertentativi ha scritto:Mikelangeloz, secondo te l' Odac XL (in pratica la versione con led e sia rca che jack) può avere problemi di alimentazione con il raspberry pi? Che faccio, ordino???
Onestamente no so che differenze ci possano essere con l'ODAC originale, ma penso che l'assorbimento sia uguale (forse qualche mA in più per via del led). Io con l'ODAC mi trovo benissimo, quindi VAI!
mikelangeloz
mikelangeloz
https://volumio.org
Messaggio Da mikelangeloz Sab 2 Feb 2013 - 14:22
davide66 ha scritto:Ciao Michelangeloz, sto seguendo il tuo progetto e sono molto soddisfatto dei risultati, complimenti!
Davide
Puoi dirmi i comandi che hai eseguito?
Hai impostato mpd.conf per prendere la musica da /mnt/nas? Hai montato il nas su nasmusic?
Dimmi se ti lista le cartelle della tua musica con il comando
ls /mnt/nas
mikelangeloz
mikelangeloz
https://volumio.org
Messaggio Da mikelangeloz Sab 2 Feb 2013 - 14:23
sontero ha scritto:ciao Mike
Suona bene .
Che trasporto usi? Che versione di raspyfi hai? Sicuramente si può fare meglio... Dimmi con che files ti da il problema (risoluzione ecc), sono mp3?
mikelangeloz
mikelangeloz
https://volumio.org
Messaggio Da davide66 Sab 2 Feb 2013 - 14:53
Ho iimpostato il fstab
http://192.168..../Musica /mnt/nas ....
dopo aver salvato ho provato ls /mnt/nas ma non vede niente
Ho provato anche a cambiare l' mpd.conf e rebootare ma non vede nessun files.
Purtroppo essendo totalmente ignorante in linux non riesco a capire come fare a trovare il percorso corretto..
davide66
Messaggio Da Menestrello Sab 2 Feb 2013 - 15:07
Cosa hai scritto esattamente in fstab?
Dopo che hai modificato il file fstab hai eseguito mount -a ?
Il file fstab serve così all'avvio il mount viene eseguito automaticamente.
La sola modifica al file però non fa nulla, se non dopo il riavvio o dopo un mount -a
Menestrello
Menestrello
Data d'iscrizione : 24.01.11
Numero di messaggi : 3131
Provincia : molesto
Impianto : bacato
Messaggio Da sontero Sab 2 Feb 2013 - 15:12
Sto usando la WaveIO .
Raspyfi versione Rc1
uso solo FLAC
Ultima modifica di sontero il Sab 2 Feb 2013 - 15:20 - modificato 1 volta.
sontero
sontero
Messaggio Da mikelangeloz Sab 2 Feb 2013 - 15:16
Occhio che anche i nomi, maiuscole e minuscole comprese devono essere uguali.
Segui questa guida, è più completa :
http://www.raspyfi.com/raspyfi-quick-start-guide/
1- Crea cartella /mnt/nas
2- dalle i permessi con sudo chmod -r 777
3- imposta il mount su fstab
4- imposta mpd.conf su /mnt/nas (verifica che i nomi corrispondano)
E' giusto l'ip del nas? Usi samba per condividere? Verifica e facci sapere (scusa ma oggi sono un pò di fretta...)
mikelangeloz
mikelangeloz
https://volumio.org
Messaggio Da davide66 Sab 2 Feb 2013 - 15:18
Dato il comando mount -a e mi dice: line 7 in /etc/fstab is bad e tra le ipotesi wrong fs type...sto usando Openmediavault con disco formattato in ext3 ..puó essere questo il problema?
davide66
Messaggio Da Menestrello Sab 2 Feb 2013 - 15:20
davide66 ha scritto:Dato il comando mount -a e mi dice: line 7 in /etc/fstab is bad e tra le ipotesi wrong fs type...sto usando Openmediavault con disco formattato in ext3 ..puó essere questo il problema?
Che c'è scritto nel file fstab?
Menestrello
Menestrello
Provincia : molesto
Impianto : bacato
Messaggio Da davide66 Sab 2 Feb 2013 - 15:25
quello che c'è scritto nella guida
http://192.168..../Musica /mnt/nas cifs username=pi,password=,uid=mpd,file_mode=0644,dir_mode=0755,iocharset=utf8,rsize=130048,wsize=4096 0 0
Ho creato in openmediavault un utente pi con la sua password ed i permessi in lettura/scrittura
davide66
Messaggio Da Menestrello Sab 2 Feb 2013 - 15:33
davide66 ha scritto:quello che c'è scritto nella guida
al posto dei puntini dopo 192.168 devi mettre i numeri che corrispondono alla macchina che condivide il file.
Per esempio, io ho un disco di rete all'indirizzo 192.168.1.9 che condivide una cartella di nome opensahre
quindi la mia riga in fstab è
http://192.168.1.9/openshare /media/musica cifs username=root,password=password 0 0
Altra cosa importante: nome utente e password non sono della cartella condivisa, ma del raspberry!
La cartella condividila senza password, quindi con accesso libero.
Menestrello
Menestrello
Provincia : molesto
Impianto : bacato
Messaggio Da davide66 Sab 2 Feb 2013 - 16:05
Si, al posto dei puntini metto l'indirizzo completo Laughing
Quello che ho cambiato è l'utente e la password...ho inserito quelli del raspberry ed ora è cambiato qualcosa...anche se mi dice che la cartella è write-protected anche se nelle impostazioni di samba l'ho messa pubblica...
davide66
Messaggio Da sontero Sab 2 Feb 2013 - 16:07
Mike ti prego non eludermi . Mi sento un po' questuante
so che hai un po' fretta . io prima ho risposto alle tue richieste di delucidazione .
hai qualche cosa da suggerire ? Smile
PS = risoluzione Flac 44.100/16
Ultima modifica di sontero il Sab 2 Feb 2013 - 16:34 - modificato 1 volta.
sontero
sontero
Messaggio Da Menestrello Sab 2 Feb 2013 - 16:09
davide66 ha scritto:Si, al posto dei puntini metto l'indirizzo completo Laughing
E' write protected perché la riga in fstab gli dice di metterla così, se non ricordo male Hehe
Ma in effetti, mpd dovrà solo leggere la musica quindi va bene no? Laughing
Menestrello
Menestrello
Provincia : molesto
Impianto : bacato
Messaggio Da davide66 Sab 2 Feb 2013 - 16:56
Ho trovato questo comando da dare prima:
mount -w -t cifs -o username=cb,password=cb http://192.168.1.1/cb /mnt/samba
dal link
http://guidainstallazionevoyagempdlinux.blogspot.it/2012/06/83-monta-disco-di-rete-con-samba-nas.html?m=0
e così le cose funzionano!
È sorto un altro problema...non riesco a spegnere o reboottare il raspberry e devo ogni volta ridare il comando mount -a...cioè do il comando e vedo i file e suono una canzone...poi do il comando reboot (o halt) ma si blocca dopo la stringa: all process ended within 2 seconds....done e da li non si muove. Stacco la spina, riaccendo e devo ridare il comando mount -a per fargli rivedere i files..e se provo a riavviare mi si blocca nuovamente.
davide66
Messaggio Da davide66 Sab 2 Feb 2013 - 17:00
Ed un'altra cosa ancora...mentre prima accedevo alle canzoni tramite mpad direttamente ora devo loggarmi tramite ssh perchè altrimenti non mi fa vedere neamche la rete wifi...una volta loggato vedo quindi la rete e mpad vede le canzoni ma devo ridare il comando mount -a altrimenti non suona niente... Shocked
davide66
