ALIENTEK D8 [parte 2]
+39
velelfo
metalgta
il Dolez
lorect
Drmirva
Alex81+
il mascetti
Umby66
dieggs
micio_mao
paolisssimo
verderame
natale55
FregaturaSicura
Luca Marchetti
giatz83
xam4033
nerojazz
CappaMatto
TODD 80
ghiglie
Enrico Ribola
magistercylindrus
43 partecipanti
Pagina 40 di 40
Pagina 40 di 40 • 1 ... 21 ... 38, 39, 40
Re: ALIENTEK D8 [parte 2]
dinamanu ha scritto:Olegol ha scritto:ma i watt sono watt , o classe A o AB poco cambia quando un ampli lavora bene
non vorrai mica riscrivere le basi dell'elettronica ??
leggiti questo che e' meglio ! LINK
Tempo perso
Numero di messaggi : 4008
Provincia : MI
Occupazione/Hobby : R&D
Complimenti Kaliun bella accoppiata Racing !!
ritiro l'esagerato
ritiro l'esagerato
dinamanu- UTENTE BANNATO
Numero di messaggi : 6340
Provincia : NoFlacx
Impianto : ClasseA
Il Poppulse di lello arriva fino a 6000 euro, l'aveva detto persino lello che era indistinguibile da un AB
https://www.audiophonics.fr/en/integrated-amplifier/poppulse-t180-t-amp-amplifier-2xtripath-ta2022-2x120w-8-ohm-p-7981.html
A member of my Forum was writing, that he had bought the Pop Pulse T 180 and that it was clearly outperforming my Emitter ( he visited me) and his own pre amp and amp constellation from Aaron for around 6000 Euro.
OK, we had a big thread in our Forum an i was curious about the very cheap Pop Pulse T 180.
But there was no way to get it, because one night after the Review of Christian the amp was sold out completely!
A Long Story and you can read in my Forum many stories! about the Pop Pulse - but here is the result:
First Pop Pulse i got from Audiophonics seemed to be damages (scratches and White noises and stinking/smelling like a wheapon) but i had bg trust in the members of my Forum who used the Pop Pulse !
Audiophonics replaced the unit immediately - 4 or 5 days later i got a new amp- my Review with Pictures is here:
http://www.boards-4you.de/wbb10/1426/thread.php?postid=5934#post5934
It is for Klipsch loudspeakers the by far best amp i ever audited in my life and was even outperforming my big ASR Emitter.9
You can be sure that you will get an amp which sounds as natural as the best tube amps do but have the power and attack of the biggest and bests high End beasts made in Class A/B.
I was overhelmed!
And now i try to get another 2 untis but Pop Pulse is still sold out, again
The Pop Pulse do outperform clearly my ASR Emitter - a shock for me!
Nadir81- Membro classe bronzo
Numero di messaggi : 1907
Provincia : Via Lattea
Cuffie:
dinamanu ha scritto:Complimenti Kaliun bella accoppiata Racing !!
ritiro l'esagerato
kalium- Membro classe argento
Numero di messaggi : 2710
Provincia : erratico
Impianto : PC con Foobar 2000
Preamp Bottlehead Quickie
Breeze modificato
Dac Douk
Giradischi Thorens Td145 mkII
Pre phono Shiit Mani
Nadir81 ha scritto:Il Poppulse di lello arriva fino a 6000 euro, l'aveva detto persino lello che era indistinguibile da un ABA member of my Forum was writing, that he had bought the Pop Pulse T 180 and that it was clearly outperforming my Emitter ( he visited me) and his own pre amp and amp constellation from Aaron for around 6000 Euro.
I was overhelmed!
400 euro per quel coso? Allora meglio i Bentam audio monoblok
Breeze modificato
Dac Douk
Lo sottovaluti...fa cascare valvolari come non ci fosse domani
Certo costa sempre troppo, però lo tengo presente come alternativa al Marantz, tra qualche anno
io lo possiedo e posso dire che è fantastico ! potentissimo e suona molto ma molto bene,l'avevo preso come ampli da sostituire al valvolare per il caldo estivo e adesso il t180 è ancora li e non ho intenzione di toglierlo !
Cuffie:
sportyerre ha scritto:dinamanu ha scritto:Olegol ha scritto:ma i watt sono watt , o classe A o AB poco cambia quando un ampli lavora bene
Tempo perso
Esattamente , meglio dedicarsi ad altro
Olegol- Membro classe bronzo
Numero di messaggi : 1338
Provincia : RIMINI
Impianto : SPACE CYCLIC
si... ma non c'è scritto hoen... e nemmeno lautstarke... sicchè è meglio di un d8... ma nulla può davanti al gigante di norimberga.... manca quella pasta sonora che tu senti e pensi... ma come cazzo si sente....
Numero di messaggi : 14434
Però l'Asr Emitter e tedesco e lo accostano al Diablo (su melius e gazebo audiofilo), e se il Pop pulse è superiore all'Emitter, vuol dire che con 400 euro e in classe D ci avviciniamo al top (Gryphon Diablo)...
Cuffie:
ma ancora con tripath dai su che fa cagar... arrenditi!!
carpiati a non finire ma che sei ?? Dibiasi !
Provincia : NoFlacx
Impianto : ClasseA
Se ala fiera dell'hi-fi di Rho avessi sentito tutta questa differenza in meglio magari mi sarei ricreduto...Se quello è il top del momento mi tengo volentieri ciò che ho...
Cuffie:
concluderei con :
"Domani aperto a pranzo
ma se leggi oggi e' oggi "
Provincia : NoFlacx
Impianto : ClasseA
Pero' forse a Rho non avevano l'xmos e questo ha castrato tutto. Ritentero' a una fiera con xmos
C'ho pure qualche breve filmato...Forse il problema era la difficoltà di riempimento delle stanze d'ascolto, ti facevano sedere pure lontano e arrivava tutto slabbrato.
Infatti le cose migliori si sentivano coi bookshelf in stanze piccole.
Cuffie:
dinamanu ha scritto:concluderei con :
Per leggere ciò che scrivete ci vuole il traduttore della lingua ...ITALIANA : altro che amplificatori e affini
Provincia : RIMINI
Da Wikipedia, rientrando in tema classe D
L'elemento di maggior interesse riguardo a questo amplificatore è la elevata qualità sonora unita al costo irrisorio di acquisto: sull'onda del successo del T-Amp, riviste di alta fedeltà di tutto il mondo hanno prodotto recensioni, la maggior parte molto positiva sulla validità audiofila dell'oggetto, con qualche eccezione.
In particolare i suoi sostenitori affermano che questo amplificatore produce un suono con un'alta qualità timbrica, un dettaglio elevato e una ottima ricostruzione dell'immagine virtuale. Date le succitate peculiarità, il soprannome che i suoi sostenitori hanno utilizzato per questo amplificatore è l'"ammazza giganti", in quanto con una spesa irrisoria compete con apparecchi enormemente più costosi.
Cuffie:
mah, il D8 l'ho avuto pochi mesi e non mi è mai piaciuto
nel mio amplificatore vintage non uso nessun XMOS e funziona meglio di quel coso digitale
Contento tu contenti tutti
https://www.tforumhifi.com/viewtopic.forum?t=53728
nerone- Membro classe argento
Numero di messaggi : 3918
Provincia : ...
Impianto : Grundig e LT
» ALIENTEK D8 [parte 1]
» ALIENTEK D8 [parte 2]
» Mc vendo alientek d8
» Più potenza di un alientek d8
Pagina 40 di 40
