Prova DAC Havana Nos a valvole e convertitore USB SPDIF Hi-end Halide Design Bridge
+13
Solomon
gianlu71
lsdmaster
Vella
Orazio Privitera
Link70
vicarious
albamaiuscola
thepescator
17 partecipanti
Pagina 3 di 3
Pagina 3 di 3 • 1, 2, 3
Re: Prova DAC Havana Nos a valvole e convertitore USB SPDIF Hi-end Halide Design Bridge
davideforbi ha scritto:... sono uno sbarbino n materia
Un semplice copia e incolla fatto da uno sbarbino come te.
Why non-oversampling DAC? ------ 'oversampling' kill music!
You may not know, the actual digital signal recorded on your CD title is 16bit/44.1k format. Yes, never doubt it! Then why almost all modern DAC feature 24bit/96k or even 192k specification? In modern digital recoding studio, music will be recorded in new 24bit/192k format but when they need to 'write' onto CD, these information rich formation must be degraded into old format. These 'New' DACs will try 'restore' the degraded back to more informative format using some talent algorithm work out by smart mathematician. ----- That is problem! why? All music you hear from CD will be processed by some smart algorithm, then you hear the artifact sound ---- actually bad sound!
My over-opinion? No! If you are a experienced audiophiles, you will find if these cd players or DACs use the same dac chip inside, they all will have very closer sound features, even their analog circuits designs are quite different. Why? You hear the same artifact derived from the same talent algorism.
These artifacts contamination did hurt your audio enjoyment! Why, they mask real tone color and even 'atmosphere' of music player. You do not believe!? Try to find CD records which also have vinyl LP version, compare music from vinyl and CD. You will know how bad these artifact sound is!
Back to vinyl record?
No! Vinyl LP really too troublesome! Listening music should be easy and relaxing.
Non-oversampling DAC is a compromise answer.
NOS-DACs may be an acceptable answer to CD music. Why? No artifact anymore from these NOS-DACs. You get non-refined music recorded on CD although it is still a degraded music. But in my experience, it is still much better than artifact juck.
Why? 'modern' dac can not De novo generate right music signal from degraded records on CD, but rather add mathematical generated fill-in bits into your music.
So NOS-DAC is a can-not-but choice!
flovato- UTENTE BANNATO
Numero di messaggi : 12509
Vintage Audio Lab copyright....
la scelta alternativa puo' essere comq quella di rendere NOS un lettore cd come ad esempio un sony 227 esd ...tanto per dirne una ...
Quindi è preferibile (sempre in linea teorica ovviamente, poi ognuno ha le sue orecchie) un dac Nos anche se si utilizza principalmente musica liquida, file Flac?
(Io il cd lo uso pochissimo)
davideforbi- Membro di riguardo
- Data d'iscrizione : 02.02.11
Numero di messaggi : 578
Impianto : Raspberry+MoOde+Allo Boss dac v 1.2
Monrio MC 200
Monitor Audio Monitor 3
davideforbi ha scritto:Quindi è preferibile (sempre in linea teorica ovviamente, poi ognuno ha le sue orecchie) un dac Nos anche se si utilizza principalmente musica liquida, file Flac?
No non è preferibile, è un tipo di suono, può piacere o non piacere.
Tecnicamente sono chip superati e a livello prestazionale non sono il massimo ma come spesso accade decidono le orecchie e non le misure.
Basti pensare alle valvole che sono quanto di più imperfetto in termini di prestazioni ma il suono che rendono è fantastico.
Non credo, ma non vorrei ritrovarmi tra qualche decina d'anni a cercare chip vintage per ascoltare la musica con piacere.
Cmq senti il parere di tutti, meglio sarebbe ascoltarlo nella tua catena.
Il ragionamento che faccio io tiene sempre in considerazione il prezzo senza il quale tutti i discorsi sono del tutto campati per aria.
Se considerei che ho speso 118 euro forse potresti buttarti, vedere se ti piace e al limite lo rivendi perdendoci sempre poco.
Questi discorsi non li puoi fare se cominici ad investire 1000 euro, li il territorio è minato, non puoi sbagliare, a patto tu non sia parente di zio paperone.
davideforbi ha scritto:Personalmente, l'accoppiata pre valvolare+ampli T (attualmente uso un pop2020 ed è in arrivo un 2070, avevo preso in consideraione anche l'acquisto del finale Trends) mi piace moltissimo
Vorrei cambiare il Dac, il superpro è stato il primo passo in questo mondo che fino a qualche mese fa non conoscevo...
Quindi mi sto guardando in giro per scegliere un buon dac, e mi è capitato di leggere un pò di cose sull'Havana... il fatto che abbia uno stadio valvolare mi ha fatto venire l'idea dell'eliminazione del pre.... ma era solo un'idea...
Ovviamente bisognerebbe fare delle prove... ma non è semplice con questi apparecchi...
Se prendi l'havana tieni anche il tuo pre ..... mi sembra un ottimo consiglio quello dell'Havana ..se hai già ascoltato un Dac NOS e quella filosofia di suono ti piace prendilo in considerazione!
Se invece preferisci fare un passo avanti con un DAC tradizionale ...sempre qui sul forum Gianlu71 vende il mio ex V-DAC evoluzione ...che è una bomba ...imho naturalmente
ma cosa prende poi gianlu71 al posto del tuo v-dac modificato...l'ha tenuto proprio il tempo di un amen!
Northstar 192 .... bontà sua ...
Io l'unico dac che ho sentito è il mio superpro, quindi mi sa che ho del margine....
...e non conosco come suonano i dac Nos... non ho mai avuto occasione di sentrli
Armando, molto gentilemente, mi ha offerto la possibilità di ascoltare il suo Havana con le mie elettroniche... vediamo se riesco ad organizzarmi
Monrio MC 200
Infatti bisogna muoversi con cautela... propio perchè non sono parente neanche un pò di zio paperone
.... comunque il v-dac modificato da stentor, in vendita da gianlu è troppo attraente.....
Monrio MC 200
Per quei soldi e considerando i materiali aggiunti direi proprio di si.
miiiiiiiii che tentazione ........
Monrio MC 200
Ho visto passare una scimmia...davideforbi ha scritto:miiiiiiiii che tentazione ........
Link70- Appassionato
- Data d'iscrizione : 27.09.10
Numero di messaggi : 405
Hai visto bene! Aiuto!!!
Monrio MC 200
Se posso dire la mia, comprare un dac con una usb che non supporta 24/96 mi sembra un passo avanti e due indietro.
Adesso esce anche l'Onkyo....
Vella- Membro classe argento
Numero di messaggi : 3992
» Shootout DDC (Halide Bridge - Hiface Evo - Weiss INT 202 - Stello U3)
» Convertitore usb/spdif
» [BS] VENDO convertitore USB/spdif Anedio € 110+ss
» Convertitore SPDIF da Coassiale a Ottica
» Autoradio Android , USB/SPDIF convertitore e DSP ampli
Pagina 3 di 3
Oggi alle 11:13 Da embty2002
Oggi alle 10:16 Da Chardonnay
Oggi alle 10:06 Da Chardonnay
Ieri alle 21:26 Da lello64
Ieri alle 21:15 Da marco123
Ieri alle 5:05 Da AndreaCD
Ieri alle 1:03 Da Gabriele1
